Clutch Problem Need help ASAP!
Old Jun 29, 2005 | 12:52 AM
Z28 97''s Avatar
Ive got the Spec 3 clutch/flywheel in, the new 01 slave cylinder bled, but the trans will not go back onto the bell housing at all. The slave throw out bearing is right agaisnt the pressure plate. The trans is like 1inch away from being able to get the bolts into the bellhousing. As hard as i push/pull on the trans it wont seat againts the bell housing. Its like the slave cylinder throw out bearing needs to be compressed more to be able to get the trans and bellhousing to mate up so i can get the bolts in to pull the two together. Spent the last hour on this!!! PLEASE help!!!!
Old Jun 29, 2005 | 06:43 PM
Josh'95Z28conv's Avatar
Re: Clutch Problem Need help ASAP!
Thats the first problem...
Old Jun 29, 2005 | 07:48 PM
teke184's Avatar
are you sure the splines are matching up on the input shaft?
can you compress the piston on the slave?
sounds like it's just an alignment problem. i had no problems getting things to slide in. now the last 1/2" or so i had to use 3 bolts tightened in a pattern to draw the trans into the bellhousing, but i was able to get it pretty close by hand.
Old Jun 29, 2005 | 08:36 PM
Z28 97''s Avatar
I found the problem. Lithium Grease is your friend. I didnt grease the shaft before i slid it foward. I sild it back greased the shaft and it bolted right up np
Old Jun 30, 2005 | 06:48 AM
teke184's Avatar
you've got to lick it...before we kick it
you've got to get it good and wet before you stick it
wise words...lube is your friend...in many situations.
but chicks don't always like lithium grease down there not sure why
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
siguy
Nov 27, 2014 10:07 AM
