Head flow #'s for boss' 67 camaro 383 T74
Well, my boss is looking for a fun street car with full spool in the 2600-2800rpm range. He only plans to run 8-10psi intercooled in his 67 camaro. The Precision T74 Q-trim was the smallest I recommended for spool time. Any smaller and the turbo would be off the compressor map's efficieny range. We were looking or a T76, but found a great deal on the T74. He just got his flow #'s for his Dart Pro 1 heads he is going to use on the 383. Lloyd Elliott ported them BTW...
237 cc intake port
74 cc chambers
Flow #'s are . . . . .
.2......142/105
.3......199/145
.4......248/175
.5......281/202
.6......302/217
.650...314/226
.7......317/229
2.08/1.625 Ferrea 6000 series valves
Comp 26120 big bee hive springs
Titanium retainers
10 degree locks
spring locators
He is having HPE build his 383 shortblock, minus the cam and have cam motion grind the cam. He is having B&G Fab do his hotparts for him. The setup should be sweet. He is hoping for 600rwhp...I think he can get there with 10-12psi. If anyone has any suggestions or ideas for the project, input would be appreciated. BTW, dont huff and puff about the turbo being too small, he wants quick spool for the street
Thanks...
237 cc intake port
74 cc chambers
.2......142/105
.3......199/145
.4......248/175
.5......281/202
.6......302/217
.650...314/226
.7......317/229
Titanium retainers
10 degree locks
spring locators
Thanks...
Re: Head flow #'s for boss' 67 camaro 383 T74
Originally Posted by 96TurboTA
How's your stuff coming along?
cool. Sounds like an interesting setup. I'll have to look it up over at ls1tech
The heads are overkill for the modest goals.
And. . . most people don't know this, but Cam Motion's oh-so-popular reverse-split turbo cams have been proven weaker than a single pattern cam in back-to-back dyno comparisons.
Mike
Mike
Mike
Mike
As far as cam motion, I have read your opinions on them and read the big thread on turbomustangs with Jim's cam dynos. I'll definitely have to think things over on that. Thanks Mike.
For several years now, the Turbo Buick crowd has been aware that reverse split cams work well when backpressure is very high, like 3:1. When they manage to get the backpressure down to <1.5:1 they'll switch over to a normal split cam.
BTW, if you can get me a legitimate 320 cfm out of a set of 23 deg, standard port location assembled heads, including valvetrain for $2000, I want to put in an order for 20 sets right now.
Castings for Dart Pro 1 230cc heads = $900
Portwork by LE = $700
Valvetrain = $400
There is your $2000
Valvetrain = $400
There is your $2000
Valvetrain = $400
There is your $2000
Dart Pro 1 230cc heads, bare = $920
26120 springs = $190
Ti retainers = $140
Valves = $100
Porting - usually, legitimate 300 cfm porting is well over $1000, but I'll only say = $700
Hyd. roller cam = $250
I'll assume the lifters are stock (free)
Pushrods = $100
Roller Rockers = $250
Total: $2650
If he bought the heads used, they may have already had good valves and springs in them. I can see the $2k estimate. Heck, I bought my Pro 1 215s for $760 completely assembled. I admit they need new springs, but that's not a big deal.
oldschool
Feb 9, 2016 09:21 PM
NewsBot
Dec 28, 2014 06:20 PM
