Fastener and injector question.
Old Jun 26, 2005 | 08:14 AM
wicked_95z's Avatar
The first question is, head bolts or studs on a 14 psi motor.
Sceond question is, does anyone use Holley /MSD injectors? Are they reliable and easy to tune idle with?
Old Jun 26, 2005 | 09:29 AM
breakmyfootoff's Avatar
Re: Fastener and injector question.
You'll get mixed answers on this. There is no doubt that studs will provide better clamping force, but do you need it? I'm using ARP head bolts, I felt that they would be good enough.
Old Jun 26, 2005 | 10:36 AM
SMOKNZ's Avatar
Bolts should work ok. I ran them up to 18 psi, I switched to studs though due to a little coolant leakage. My heads ended up being a little warped, so I had them surfaced .006 and switched to studs with no further problems.
Any injectors should idle fine as long as you have the right constants and offsets for your specific injector. Guys get large injectors to idle fine, it's all about the tune.
Old Jun 26, 2005 | 09:24 PM
ddnspider's Avatar
do it right the first time and get studs....not worth the mess that coolant can cause my leaking.
Old Jun 28, 2005 | 12:11 PM
96PTKZ28's Avatar
Corky bell said it best in his book Maximum Boost, "Head bolts are an accountants decision, a head stud is an engineers decision".
Old Jun 28, 2005 | 12:33 PM
wicked_95z's Avatar
Good enough for me. Thanks everyone.
13qtr
Oct 28, 2016 08:11 PM
93 RedBird
Nov 15, 2015 08:24 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
