Vortech Sucks!!!!!
Old Jun 21, 2005 | 09:07 PM
BCAUTOSOUND's Avatar
Vortech Sucks!!!!!
I would extremely recomend people look at another manufactuers product. I have went through a nightmare with my kit i bought from them. Got the whole kit installed and got to the last step and the tensioner pully wasn't in the box. Called vortech last friday they said they would next day air it. Monday came no tensioner. Called back said was still on the shipping table would send out that day. Tuesday comes no show. Will update the story tommorrow.
Old Jun 21, 2005 | 09:28 PM
BADST95's Avatar
Smile Re: Vortech Sucks!!!!!
Dude... relax... it's not the end of the world. Ask them for some free stuff for your time. T-shirts, hats, etc.
Old Jun 21, 2005 | 09:33 PM
Z8'S's Avatar
Sounds like you're a little upset
Heck I would take the whole kit off and demand my money back
That would show them
You could have gone to a local Ford dealer and got that part and had it running already and probably been reimbursed by Vortech.
Thanks for the heads up, I wouldn't want to put any parts that suck on my car
Old Jun 21, 2005 | 09:56 PM
engineermike's Avatar
I had a similar problem in that they left out the harmonic damper that's supposed to come with LT1 kits. Since I was also in a hurry (no reason except impatience), I had Vortech fax me a drawing so I could machine the stocker to the correct dimensions.
I never mentioned to them that they accidentally sent a 6.66" crank pulley instead of the damper.
Mike
Old Jun 21, 2005 | 10:05 PM
BADST95's Avatar
When all else fails... get on the internet and b!tch.
Chris... your car is weak... I know... PSJ told me so.
Old Jun 22, 2005 | 12:26 AM
sprayedtransam's Avatar
Yep Yep. I have a Ford tensioner pulley on mine .
Old Jun 22, 2005 | 06:49 AM
rskrause's Avatar
A little over-reaction??
Rich
Old Jun 22, 2005 | 09:25 AM
BADST95's Avatar
Thumbs up Re: Vortech Sucks!!!!!
Originally Posted by aggiez28
vortech
Beh... Procharger is far better.
Old Jun 22, 2005 | 10:06 AM
BADST95's Avatar
Thumbs down Re: Vortech Sucks!!!!!
turbo > vortech and procharger
Oh yeah... that STS kit is top quality.
Old Jun 22, 2005 | 11:52 AM
rskrause's Avatar
Is that so? Either can be made to work well. I think a centrifugal is easier to install.
Pump gas P'charger F1 383 through a loose converter with a crappy single exhaust. I bet there's another 50-75hp with a good exhaust system.:
http://www.kennedysdynotune.com/images/dynograph.jpg
Rich
Old Jun 22, 2005 | 12:44 PM
RocCityZman's Avatar
Rich
Is that yours Rich?
Old Jun 22, 2005 | 02:04 PM
rskrause's Avatar
Originally Posted by RocCityZman
Is that yours Rich?
Guilty as charged.
Rich
Old Jun 22, 2005 | 02:46 PM
BADST95's Avatar
Hmmm... Maybe I should spin my engine to 7200 rpms.
The 'Bird dyno graph
No nitrous.
Old Jun 22, 2005 | 05:20 PM
Lisa33's Avatar
Rich
nice numbers, what pulleysizes do you use and how much boost do you see?
Im running a 7,65/3,7" pulley setup (17psi at 6500rpm) on oure pumpgas 8.5comp 383...
Can you spec a little more info, like comp, timing (wot), heads, cam etc
Thanks
ake
Old Jun 22, 2005 | 07:34 PM
rskrause's Avatar
Those runs are made with a 2/1 pulley ratio, can't recall the exact size. For testing, I removed the intake piping and in that configuration it sees 21-22psi. With the intake installed it drops to ~17psi. The motor is a 10 over 3.75" stroke "383". Fairly radically ported AFR 195's. 7.8:1 CR. Water injection.
Rich
