Can too much timing retard case misfires?
Old Jun 18, 2005 | 04:52 PM
davepl's Avatar
So I've been chasing a high RPM random miss for about a year, and today after installing a new set of 83# injectors from Jeff Stevens, I decided I'd try my alcohol injection system that I built as as well.
I put the fuse in, a 30# NOS jet in the alcohol injector nozzle, and upped the timing tables from 20 to 24.
The miss, for whatever reason, got a little better. I upped it to 28 degrees and the miss went away.
To make sure it wasn't related to the alcohol itself, I pulled the fuse, went back to 24 degrees, and it was still pretty much gone, especially compared to what it was at 20 degrees.
Does this give anyone a hint as to what might be up with the motor? Since I'm running a hot 12psi non-intercooled, I had to back the timing out to 20 degrees to avoid any knock retard. But that seems to cause my motor to miss.
Other details: 396 LT4, 210cc AFR heads, 238/238 cam, S-Trim
Thanks,
Dave
Old Jun 19, 2005 | 01:13 PM
davepl's Avatar
Re: Can too much timing retard case misfires?
Really? No one has an idea? Everyone on vacation?
Ok, how about this: 20 degrees BTDC is closer to TDC than 28 BTDC, so the cylinder pressure at 20 is a lot higher than at 28, and if you have a marginal ignition problem, it might not be able to fire across the gap under boost at 20 BTDC even though it can at 28 BTDC.
It's not a forum if I'm talking to myself :-)
Old Jun 19, 2005 | 10:12 PM
blown3rdgen's Avatar
Yes retarding timing to much can cause problem. Friend with a BIG nitrous motor had to go to a crank trigger set up to avoid the possibility of misfire/arching cyl when pulling timing out with a multi stage kit. However, 20* should not be a problem at all other than maybe giving up a few hp- many of the guys over at turbomustangs.com are in that area.
Matt
AdsoYo
May 2, 2018 03:21 AM
mikey4play
Mar 15, 2015 11:45 AM
Alex Barnes
Jan 24, 2015 10:21 PM
