what the hell is an exhaust mount doing here..
Old Jun 4, 2005 | 04:54 PM
sabre81's Avatar
According to http://www.afrashteh.com/tranny_pics/T56.htm, i need an exhaust mount for the swap? where? and what? im confused.
Old Jun 5, 2005 | 12:30 AM
Re: what the hell is an exhaust mount doing here..
As I recall, there's a bracket to support the cat, bolted to the tranny tailshaft housing. Its held on by the same bolt that holds the TA bushing. At least there was one on my T56 with single cat. Check out the exploded view on Shoebox's Tech Pages, part #31 may be the one.
http://shbox.com/1/exhaust_system.jpg
Old Jun 5, 2005 | 08:21 AM
Z28Nut's Avatar
Yeah, my A4 single (former) cat car has a bracket to hold up the rear of the cat - or ORP - attatched opposite the torque arm bushing mount. So I imagine the T56 needs one, too, to support the cat and front of the catback.
Old Jun 5, 2005 | 02:42 PM
GMH94Z28's Avatar
Do you have to use the exhaust hanger? When i did the swap from a4 to t56 i didnt have one and i have a straight pipe where the cat used to be. Thanks
Old Jun 5, 2005 | 02:51 PM
Z28Nut's Avatar
The exhaust is held up by the manifolds/headers, trans bracket, and muffler hangers. Without the trans bracket that's a lot of pipe just to be held up at each end. The connections - unless everything is welded - are going to have too much stress on them and will sag and eventually leak.
Old Jun 5, 2005 | 03:24 PM
sabre81's Avatar
what is that black plate in the middle here.... http://www.thirdgenparts.com/92LT1RS/T563.JPG
Old Jun 5, 2005 | 03:58 PM
Lisa33's Avatar
justy skip it, havent got anything else than the 2 frame mounth fasterners on my 4" exhaust, no problems at all...
http://home.koping.net/u3243a/vinter...5/DSC02413.JPG
Old Jun 5, 2005 | 08:20 PM
Z28Nut's Avatar
Basically a dust sheild for the bottom front of the bellhousing. The hole in it is for the starter nose.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
HarleyZ28
Oct 5, 2015 06:23 AM
Alien
Jun 27, 2015 01:13 PM
NewsBot
Mar 19, 2015 12:20 PM
heavenly_six
Dec 10, 2014 12:23 AM
