Coolant Flushing...
Old May 23, 2005 | 06:10 PM
hatredizm's Avatar
Coolant Flushing...
I have a 97 Z28 A4 and think its time to flush the coolant. Im sure I remember seeing a Dexcool label somewhere, but it has the normal green coolant in it. When I check the fluid level through the coolant adding spout, parts of the plastic level checker looks like it is caked with mud or chocolate milk. Any advice? Thinking of having a shop flush and clean the system.
Old May 23, 2005 | 07:16 PM
fredmr39's Avatar
Re: Coolant Flushing...
You should have the Dexcool in there - maybe someone mixed the green in or didn't completely flush the Dexcool and thats why you have mud/sludge. Be sure to flush it well and completely remove everything - then fill with Dexcool or the green stuff (factory fill is Dexcool for your car).
Old May 23, 2005 | 08:30 PM
lt11997's Avatar
Green coolant is fine as long as you don't mix it with dexcool.
Old May 24, 2005 | 04:38 PM
hatredizm's Avatar
Thanks guys. I want to have it flushed and put the green back in so its less of a hassle to maintain.
Old May 24, 2005 | 04:43 PM
fredmr39's Avatar
Most guys I know do not have any problems with Dexcool - the one I know personally that did used tap water while the other's used distilled only - but you can't go wrong with the green stuff!
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
