pics of coils mounted to radiator.. ??
Re: pics of coils mounted to radiator.. ??
Delteq or LTCC??? I've got my Delteq coilpacks mounted cross-wise on the intake between the cowl and Shock-Tower bar... Don't have pics online yet, but it works great. none of my plug wires are over 2' and all are almost the same length.
The way I have mine mounted would be perfect then, I can e-mail you pics if you want...
I basically modified the Valve-cover mount by removing the mounting bosses, and drilling 4 holes; then just fabbing up 2 aluminum rails about 10" long which mount using the 4 Fuel-Rail bolts; then the Valve-cover mount bolts to those 2 rails. Worked awesome.
