best stock fuel inj??
Old May 17, 2005 | 01:52 PM
Runin2Nite's Avatar
I have a 88 305 tpi not to sure about the size inj. i plan on gettin the adjustable fuel pres reg soon......what are the bast fuel inj i can get. like out of a stock car. lt1 (possably inj out of a v6 4th gen??)
Old May 17, 2005 | 02:37 PM
Rice Killer87's Avatar
Re: best stock fuel inj??
Its hard to remember,but I THINK 305's came w/ 19 lb/hr injectors,L98's had 24 lb/hr and LT1's have 26 lb/hr.
Unless you have alot of work done to your 305,I would stick w/ the stock size injectors but buy an AFPR like you had mentioned.
Old May 17, 2005 | 03:05 PM
iansane's Avatar
305tpi's -- 19lb/hr
350tpi's -- 22lb/hr
Are you looking through junkyards? All the JY's around here won't let you rip things like that off, they want to sell the whole thing complete...
EDIT: Are you burning your own chip? If not, bigger injectors aren't going to be the proper way to improve fueling. It'll either be lean at high RPM and good and idle/part throttle or rich at idle/part throttle and okay at high RPM. I bet it'd work, just not all that well.
Old May 17, 2005 | 11:02 PM
Runin2Nite's Avatar
thanks for tips
Dec 1, 2016 05:37 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Catmaigne
Dec 25, 2014 12:16 PM
