Why are 98+ fenders needed for conversion
Old May 15, 2005 | 11:52 PM
94-3.4's Avatar
Can someone tell my why you must replace the fenders for a 98+ front end swap. I got my hood today and it seems to be alright with the 93-97 fenders despite some fiberglass problems. I don't have a bumper cover yet though. Is this where the problem is?
Old May 16, 2005 | 12:34 AM
94Z28WP's Avatar
Re: Why are 98+ fenders needed for conversion
I know one difference... 93-97 the front part of the fender is enclosed... The 98+ has a small opening for the headlights.
Old May 16, 2005 | 09:54 AM
BlueV6's Avatar
yes, that is right
http://www.davidyeatts.com/images/Ja...nd_effects.jpg
http://www.davidyeatts.com/images/F-...heels)%201.jpg
Old May 16, 2005 | 01:45 PM
Highlander's Avatar
i think they "could" be used
it might look weird tho.
Old May 16, 2005 | 06:22 PM
meissen's Avatar
If you used the stock 93 fenders, you'd have to cut them to make room for the headlights. You could do it that way, but it'd probably be easier to just buy new fenders unless you're very comfortable with doing custom body work.
Old May 16, 2005 | 11:00 PM
94-3.4's Avatar
Well I discovered another difference other than the headlights. There is a lip on the fenders that runs the length of the engine bay that the hood sits in. Without out it a hood (glasstech pin on) sags in the middle without it. Sucky.
Old May 16, 2005 | 11:12 PM
RacingTiger04's Avatar
i dont know if thats really the difference, my hood sags in the middle on my 94 anyway unless the shop ordered the wrong year... but since it doesnt hvae the bubbles coming back from the headlights ill assume they didnt. anyway gl with the conversion!
Old May 17, 2005 | 04:56 PM
meissen's Avatar
Hmm, that might be a specific problem with that type of hood. If the 98+ fenders have it and the 93-97 don't, then wouldn't all of the 93-97 hoods sag in general as well? I've seen conversions done where the only modification was the changing of the front clip's body panels & hood, and his bolt-on hood fit ok (atleast I haven't heard any complaints of sagging).
Edit: in re-reading my own post, i realized I didn't really make sense, and rethinking about it if they did a conversion from a 93-97 to a 98+ frontend, then they have the 98+ fenders that have that necessary lip which supports the hood, and hence of course wouldn't have a problem sagging.
Old May 17, 2005 | 09:50 PM
94-3.4's Avatar
The hood is a pin on glasstech so it is a lightweight race hood and not very strong to begin with, but it appears to need that lip for it to sit in. Anyone know where I can find some fenders?
Old May 17, 2005 | 10:20 PM
CeeBee94Z's Avatar
From what I understand I think the height of the fenders are different between the two front ends as well, not just the way the headlights fit into the hood.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
