98 K1500 4l60e trans bolt in for thirdgen?
Old May 15, 2005 | 09:53 PM
Reno Leigh's Avatar
Anyone ever done this swap before? Is the stock truck tailshaft length compatible with the stock driveshaft etc from a thirdgen????
Old May 16, 2005 | 01:04 AM
iansane's Avatar
Re: 98 K1500 4l60e trans bolt in for thirdgen?
First off I've never seen that transmission and I don't know much about it.
Now that that's out of the way. The "e" on the end of the 4l60 designates that it's electronically controlled. No thirdgen ever came with the e-controlled tranny. Only fourthgen. I also know that at least on older 4l60/700r4 trannys the tailshaft between 4wd and 2wd are different so the transfer case will bolt up. Along that same line, I'm geussing the 1500 doesn't use a torque arm setup on the rear axle so you'll have no way to bolt your stock one to the transmission.
And does the 98 have the LS* based motor? If so the bellhousing won't bolt up to the older style gen1 small block.
HTH
Old May 16, 2005 | 05:23 PM
Mojave's Avatar
98 was the last year of gen 1 small blocks in the trucks, and the Suburbans still had the old small blocks in 99 as well.
Old May 16, 2005 | 06:03 PM
greezemonkey's Avatar
Yep it`ll bolt in............that`s it though. The 4l60e is shifted by electric selnoids that are commanded by the pcm, yours wont do that. The transmissions pretty much broke down like this: up till 92 it was named the TH 700R4 shifted by throttle valve and governor...93-97 The 4L60E shifted by the PCM and torque converter lock up was beginning to be used more like a clutch than an ON/OFF. 98-99 4L60`s Bellhousing is now removable from the case and torque converter is controlled thru a pulse width type modulator for accel and decel. The 4L60`s that came with the LSx motors will bolt up, pattern is the same minus 1 bolt hole input shaft lengths are different I think though
Old May 16, 2005 | 11:11 PM
Reno Leigh's Avatar
Thank you guys
Old May 17, 2005 | 02:23 PM
Tru2Chevy's Avatar
Actually it was only the 700R4 until 89 or 90. In the (90) 91, 92, and 93 F-bodies it was a 4L60, and from 94 up it was the 4L60e.
There were minor revisions along the way, howver the electronic control in the 94+ was the only major difference.
- Justin
Old May 17, 2005 | 05:53 PM
<-- bows in ignorance
Yes that is right, I should re-check what I wrote in the morning after a few canadians at nite
HectorM52
Jul 30, 2017 11:46 AM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
Jan 5, 2015 07:14 PM
