the biggest tire size?
Re: the biggest tire size?
If you go strictly by the tire manufacturer's recommendations, most manufacturers do not recommend anything larger than a 285/35-18 on an 18x9.5" wheel. They would typically recommend a 10" wide wheel for a 295/35-18, but you might be able to get away with that.
Whether or not the tires rub on anything will be determined by the offset of the wheel.
carguy0119
Apr 11, 2016 11:11 PM
