Just got my new rotors in...
Old May 2, 2005 | 06:34 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
The directions say that you MUST use new brake pads when installing new rotors...
why????????
my stock pads have more than half life yet... im not getting rid of them
i think this is just a ploy to get you to buy more of THEIR product... of course they recommend their own.
do i really HAVE to change my pads???
Jared
Old May 2, 2005 | 07:09 PM
respectirocz's Avatar
Re: Just got my new rotors in...
what usually happens, especially with semi-metallic pads, is the pads form groves in the rotors and thus, when set, the pads work best with their matched rotors and if installed on a different set of rotors, would increase wear, put your finger on the original rotor, and if its grooved, go get a set of pads from any autoparts store, if their perfectly smooth (both viually and physically) then go ahead and re-use them
of course if you dont want your pads to eat up these rotors go with NAO (non asbestos organics, not usually available for front brakes) or ceramic pads (usually more expensive, around 45-50 bucks)
Old May 3, 2005 | 11:00 PM
RE AND CHERYL's Avatar
If you going to the trouble to change rotors, why not change pads. But if your too cheap to change the pads I would at least take a belt sander of something simular to the pads to remove the glazed surafce from the pad so the rotor can have a fresh surface to bed to.
93 RedBird
Nov 15, 2015 08:24 AM
HibachiZ28
Nov 6, 2015 12:53 AM
jayblev95
Sep 26, 2015 09:44 PM
Henson071
Sep 18, 2015 04:01 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
