How to remove e-brake cables
Old May 2, 2005 | 09:58 AM
IgorT.455/406's Avatar
Hey guys. I need to remove the e-brake cables from my car, while still leaving the calipers attached to it. I'd like to remove the entire assembly and transfer it over to another car. I was looking at it yesterday, not sure how its done. Need help.
Thanks a lot guys.
Old May 2, 2005 | 12:17 PM
ubiquitus's Avatar
Re: How to remove e-brake cables
release tension from the outside half moon gear on the e-brake handle, take off the rear wheels, unhook wheel cables from hook on caliper, use pliers of some sort to squeeze fitting at the bracket on caliper (do this to each side), in the center of the car above the driveshaft disconnect from the 'y', use pliers again to take all the fittings out of their holders (may require cussing), detach the cable from the e-brake handle and pull all 3 out.
KYWes
Jun 14, 2022 06:52 AM
DSMKilla
Jun 11, 2015 05:02 PM
grabbem88
Feb 10, 2015 06:20 PM
pologreen97z
Dec 2, 2014 10:42 AM
