Pro Fabrication thoughts
Old May 1, 2005 | 08:04 PM
cpt_bimes's Avatar
How many of you guys have tried pro fabrication? Well let me save you the grief and money. they suck ***.
Tubular K-member - sent without bolts, and did not have brackets to mount brake lines.
Subframes and "one bar" TQ. arm setup - the bracket that bolts onto the pumpkin did not fit. I had to grind off about a 1/2" of **** because they assumed that if the plate fit on the bottom of the pumpkin, it would fit on the top of the pumpkin. Then the TQ. arm was too long. It allowed for no room in adjustment of the pinion angle. The driver's side subframe connector hit the y-pipe coming off the driver header. And i dont mean just rubbed. It overlapped the thing by about 5 inches. it would not even work with a stock Y-pipe. The passenger side fit fine. They "mirrored" the subframes. Just because one side fit doesnt mean the other side will fit. Keep in mind none of these parts came with bolts.
My buddy had already ordered a new Pro Fab rear end, so if that comes in and its ****ed up, no more business from profab.
THey need to fire the retard in Research and Development and tell him that just because it fits on a drag car, doesnt mean it will fit on a street car.
Dec 1, 2016 05:37 PM
Apr 3, 2015 10:54 AM
maybe2fast
Mar 13, 2015 11:48 AM
FredM
Mar 6, 2015 03:04 PM
