HELP!!! Im confused
Old Apr 29, 2005 | 01:55 PM
KirbyZ28's Avatar
HELP!!! Im confused
Ok I have a 2000 Z28 A4 and i just reciently put a NX Wet Kit on it everything worked good and so on well i was out racing a Corvette and after we got done racing i could smell OIL so i got off of the E-Way and pop my hood and i see that the Oil dipstick has came out and there is oil all over the engine (This only happens when I am Spraying) Now i know that the reason that it is doing this is that there is to much crank case pressure but why would it do that ... Rings? (I Hope Not!!)
Thanks
Old Apr 29, 2005 | 04:35 PM
LameRandomName's Avatar
Re: HELP!!! Im confused
Originally Posted by KirbyZ28
Rings?
That's where MY two bits are.
Old Apr 29, 2005 | 08:30 PM
InsuranceGuy's Avatar
Most likely cracked/broken ring lands.
With your engine idling, remove your oil fill cap and see
if you have the chug-of-death(blowby)coming out of the
valve cover. If so, its time for that rebuilt. Been there, done
that(twice).
Emil Dusek:93Z
Old Apr 30, 2005 | 07:54 AM
profat54ht's Avatar
Re: How do I know if I have a true 1968 Z/28???
We just bought a 1968 Z/28 so we were told. Is there any web site we can check out vin # or cowl tag #'s?? Thanks profat54ht
Old May 1, 2005 | 10:23 PM
Nitro Dave's Avatar
Take and do a compression test on the car.
This will tell you if there is ring problems.
Dave
Nayr
Mar 3, 2023 08:34 PM
Javi Fierros
Exhaust System
10
Apr 20, 2017 12:46 PM
Boss002
Jan 20, 2016 12:17 PM
raroz28
Sep 8, 2015 06:10 AM
lildemars09
May 28, 2015 07:54 PM
