lowered 4th gens
Re: lowered 4th gens
Originally Posted by musclecar
I put Intrax springs in mine and it seems to be on the bump stops in the front...lol I rides ROUGH!! Looks cool tho!!
I've also heard that the BMR springs suck......??
It really didn't measure that much with a tape, but then again I don't know how much travel these cars have. I was told the springs were 2-2.5 but installed are more like 3. I have 18's on my car and wanted to close up the gap in the wheel well so I figured I would try them out!!
Originally Posted by Bayer-Z28
I heard Intrax were awesome springs.. How low did you go? I'm looking at a 1" drop w/ the 17" SS wheels, same ride height from a stock 16" Z28 wheel..
your factory tires were supposed to be 245/50/16, not 255
when you calculate tire diameter between 275/40/17 and 245/50/16, it comes out to less than 1/10th of an inch. (in a perfect world)
1 coil cut from the front stock springs, 3/4 coil cut from the rear with isolator removed and heat hose on the top coil.
26" front height, 27.25 rear.
with st35mm swaybar, bilsteins, gw upper controls arms. it handles pretty good and the ride is far superior that stock.
-1.7 camber, 4.5 caster, 0 toe in.
carguyshu
Jan 22, 2017 11:19 AM
HectorM52
Jan 31, 2015 07:29 PM
formula79
23
Jun 20, 2002 01:42 PM
I cut my stock springs
and have for years with no ill effects. 27 inches all around
