Spraying Lt1
Old Apr 28, 2005 | 08:42 PM
jaredwayt's Avatar
Spraying Lt1
i was just wondering if this seems possible.
-say i have a low mile lt1 with basically stock around 285RWHP/311RWTQ
-if i where to upgrade the injectors/fuel pump with a wet kit and spray a 125 shot and had it dyno tunes perfectly will it be possible to put down over 400RWHP???and perhaps with the right rear-end/suspension go into the 11's???
thanks.
Old Apr 28, 2005 | 10:53 PM
OBE1 95Z28's Avatar
Re: Spraying Lt1
First off, a wet kit doesn't need a change in injectors. Fuel is added through the same nozzle that the nitrous flows through (hense the name WET kit).
I have a friend with a stock LT1 with CAI and a cat back system. With a 150 shot and a set of borrowed ET Streets, he ran a consistant 11.6.
Fatdog2
Feb 13, 2015 08:19 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Redbird
Aug 12, 2002 08:51 AM
JSK333
Jul 31, 2001 04:10 PM
