Rear End / Tranny Fluid
Old Apr 20, 2005 | 06:38 PM
aaron_depue's Avatar
I own a 94 Z-28 LT1 Auto Tranny. My question is: How much rear end fluid and Tranny fluid are you suppose to put in after you change the fluids?
Old Apr 20, 2005 | 06:51 PM
BLinindoll's Avatar
Re: Rear End / Tranny Fluid
Till they're full. More specificly... Fill the rear end untill it is at the bottom of the fill hole. About 3.5 pints. Fill the tranny till it's the right level on the dipstick with the engine warm and running. Not exactly sure how much it takes to refill after a drain, but the tranny holds 10 pints all together. You won't even come close to putting in 10 quarts though.
Old Apr 20, 2005 | 07:00 PM
JBird33's Avatar
Also, make sure that you use the equa-torque additive for LSD rears. Without it, bad stuff can happen to that rear end of yours.
Hey BLinindoll, just so you know, no 4th gens came with factory 3.73s, like you said in your sig. It was either 2.73 or 3.23, depending on the option when purchased.
Old Apr 20, 2005 | 07:07 PM
BLinindoll's Avatar
RPO code GT4 actually. Right on the inside of the glove box. Factory codes don't lie.
Old Apr 20, 2005 | 07:58 PM
WarGoddess's Avatar
Just rebbuilt a 97 4L60E (tranny) and it took 11 quarts total for the fill. My teacher recommends 4 quarts without starting, and when you go to put the 5-11 quarts in, you have the car started.
Old Apr 21, 2005 | 06:31 AM
BLinindoll's Avatar
Right, but when your just draining the tranny, only a fraction of the fluid comes out. For example, the torque convertor holds about 3 to 4 quarts which doesn't come out when you just drain the tranny. When you do a total rebuild the tranny is dry and you have to put it ALL back in, including filling the torque convertor.
Old Apr 21, 2005 | 08:20 AM
WarGoddess's Avatar
In which case the specs from A-zone state that 5-6 quarts should be used. Sorry, should have stated that before.
Old Apr 21, 2005 | 01:25 PM
Does Royal Purple have the additive that you are talking about here?
So 2 quarts for the rear end and 6 quarts for the tranny?
Im gonna do all of it this weekend and was really needing to know how many quarts of rear end and tranny fluid to buy
Old Apr 21, 2005 | 02:26 PM
BLinindoll's Avatar
3 quarts of rear end (castrol makes one for additive for limited slip) and 6 or 7 quarts of tranny. Extra never hurt anyone.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
FredM
Dec 18, 2014 01:40 PM
