1st thread! Transmission problem! I need your help!
Old Apr 20, 2005 | 09:29 AM
Nightshift187's Avatar
Hey guys! This is my first thread, but I've had my car for about 3 years. It's a black 1995 Camaro Z28 v8! I think I've got a problem, you see something has been making a noise underneath the transmission for a while now, like a knocking noise, you can hear it lightly when driving regular but hear it pretty good when you accelerate. Well, recently my gears (it's an automatic ) got stuck and when I tried (kinda hard) to put it in park I guess I tried a little too hard and well, now my car won't reverse and it won't park, you just have to turn the car off and pull up the E-brake. Also, my car can now only be drivin about 15-20 mph, any faster and it sounds like somethings gonna blow. My questions are, what (do you think) the problem may be? Will I need to replace my entire transmission? Also for the big question, how much do you think it'll run me?
Thanks guys, and it's a pleasure being here! I'll make it a priority to come here often as I plan on hooking my ride up! Keith
Old Apr 20, 2005 | 09:35 AM
1-bad-z28's Avatar
Re: 1st thread! Transmission problem! I need your help!
the thumping is the torque arm hitting the underside of the car. Check the mount on the side of the tailshaft housing on the tranny.
The other problem could be as simple as something causing the shift lever not to move but it could be problems inside the tranny. You might need to have it rebuilt.
Old Apr 20, 2005 | 10:16 AM
Thanks for the info, i'll check the torque arm, is that an easy fix? The tranny will probably have to be rebuilt, it's got 139,000 miles on it, and as always I'm expecting the worst situation that could happen. Any idea on the price with labor seeings how I have no experiance whatsoever in this type of situation?
Old Apr 20, 2005 | 10:18 AM
blind527's Avatar
I didn't have any experience either, but the installation was cake.
If you want to do some "free mods" to your car, there are a few easy ones you can do.
Old Apr 20, 2005 | 10:27 AM
What exactlly was "cake"? What did you install on your car?
Old Apr 20, 2005 | 10:55 AM
1-bad-z28's Avatar
it is probably the mount came apart. It happened to me a week after i got the car. Prices on tranny rebuilds vary from area to area. PM camaro4lifess about it. His dad owns a transmission shop and he is the builder. He can give you a better idea of what it takes and how much they charge but like i said it will vary.
Old Apr 20, 2005 | 04:10 PM
Re: 1st thread! Transmission problem! update!!!: LINKAGE PROBLEM!
I just got the call back from the guy at the shop! He said that my car's transmission has the wrong size linkage, and that was the problem. That's all that he said though, so does it sound bad? Also, anybody know the price of some transmission linkage work? Let me know all you can guys I'm really needing help here and any little thing or past experiance from you would really help me out!
THANKS!
edxiel
Jan 24, 2015 07:40 PM
CaRParts102
Dec 6, 2014 08:45 AM
simple
Aug 2, 2002 03:30 PM
JasonD
Jul 15, 2002 02:17 PM
