Need some help with TPI NX system hook up?
Old Apr 18, 2005 | 09:48 PM
Wishmaster's Avatar
WEll I just spent me a bunch of money....I got me a 2800 stall from midwest and purchased an EFI NX wet kit for my little 305 with the works, Purge, Remote Bottle Opener, Bottle Heater, FP saftey switch, NX switch panel, NX electric nitrous gauge, MSD Digital 6 +, MSD digital Window Switch, digital trans temp gauge, Digital A/F gauge, autometer dual gauge pod, single gauge pod.
WOW!!!!!!!!!! All that just to blow my motor...LOL!!!!
My question is, any of you guys with a MAF TPI running an NX wet kit? how did you or where did you put the shark nozzle? Seems like it would be hard in the acordiun(Spellin) boot thingy. Can you post some picture? SO I can see?
Her in the future Im going to be asking alot of question from you guys ttrying to get this stuff work....so bear with me..
thanks!
Old Apr 19, 2005 | 06:59 PM
Wishmaster's Avatar
Re: Need some help with TPI NX system hook up?
anyone? atleast a place that has some pics or somthing? Im sure somebody know someone with an 80's camaro that has the shark nozzle on their TPI..
thanks!
Old Apr 19, 2005 | 08:41 PM
96m6lt1's Avatar
i have had plenty set-ups like yours.you are supposed to instal the nozzle after the MAF about 4-6 inches ahead of the TB,looking into the boot when mounting nozzle to be sure it is in-line with the butterflies,on one of my 305tpi cars i used the 150 pills,5-speed,3.45 gears(aussie9),hooker shorties(personal fav. on 3rd gens)flomaster amer.thunder made many mid 12 sec passes on m&h racemasters,i had a 383 sitting ready to go in and blew the 305 up,4500 rpm launch and 5800 rpm shifts.so if you poped the motor on less than 150 you had a motor that was gonna go anyway, considering your tune was safe colder plugs,new cap,rotor,wires, safe timing would have been 6*,and good fuel pressure....
Old Apr 19, 2005 | 09:13 PM
Wishmaster's Avatar
thanks for the reply...my motor runs strong right now so Im thinking its gonna be ok......doesnt blow any oil or anything.....I run consistent 9.1's and 14.2's
With an auto I damn sure wont be leaving at 4500...WOW!!!...LOL Ive got the 2800 stall going in too...so I guess I would be leaving at about 3 rand or so...and Im figuring to have it set to sut off at 5000....jus to be safe.
With your TPI car did you have the flex tubing? that you mounted your nozzle on... its not a flat surface so how will it make a good seal?
Old Apr 22, 2005 | 08:03 AM
Zepher's Avatar
I've got an NOS plate and throttle cable bracket that I will sell since I don't plan on putting the spray on the car anymore.
dfarr67
Apr 10, 2015 07:44 PM
kennyirocz
3rd Gen / L98 Engine Tech
Feb 7, 2015 11:41 PM
89 iroc zl1
Jan 14, 2015 02:18 AM
4586
Dec 6, 2014 05:20 PM
30thZ286speed
Aug 3, 2002 04:54 AM
