12v source?
Old Apr 17, 2005 | 11:50 PM
96blkform's Avatar
12v source?
Got all the lines run and the wiring apart from the 12v source to the system. Wanted to find out which 12v accessory source you guys might use for your NO2 arming, purge and bottle warmer. Also did you wire a fuse in and what fuse size to run? Thanks guys, this is the final peice and then it is time to test the system out
Old Apr 18, 2005 | 01:32 AM
Black1995Z's Avatar
Re: 12v source?
Here's what I used! Perfect location GM!
http://shbox.com/accy/Accessory.html
shoe box kicks ***
walt355
Mar 16, 2016 09:35 AM
4586
Aug 22, 2015 01:09 AM
4586
Aug 18, 2015 07:08 AM
whitehooptie
Jul 12, 2015 06:10 PM
gelbza
Jul 12, 2015 08:10 AM
