STS VS. Supercharger.........???
Old Apr 17, 2005 | 09:09 PM
Bayer-Z28's Avatar
I tried searching, it didn't help me much...
It's up in the air right now. I found a good price for the STS kit. I've heard of a guy getting an ATI for cheaper than the STS.....???.......?????!!!HOW???!?!!!!
Last time I priced the ATI it was insane pricey!! Unless I'm not looking in the right places...
I like the STS theroy...GENOIUS!! I've allways liked turbos, BUT.........I've also allways like the superchargers.....
Pro's......cons....???I understand that the supercharger requires power for it to be driven, and the turbo needs only exhaust flow....possible backpressure gain..What size injectors will I need and what size fuel pump....soemthings I have no prob figuring out, but this isn't one of them....I'm lost.....
I've also heard of ppl not liking the idea of having an oil line running the leingth of the car....well, we've got fuel lines running the same length...but that won't kill the motor, just set the car on fire....
help!!???............?????
Old Apr 20, 2005 | 10:57 AM
Kredz28's Avatar
Re: STS VS. Supercharger.........???
Heres the way i look at it...STS work, but not as good as an underhood setup. Due to the volume of piping used you recircualte air from turbo to engine, there is an issue of lag. Not to mention if you decide to go with a custom fab front mount setup, there is even more volume to fill.STS claims that the pipes from turbo to TB bleed off some of the heat, and provide a 50% intercooling efficieny. I just bought a D1SC procharger kit for my z28, and am happy with my decision. I have seen the STS turbos go bad because of a piece of ceramic from the Catalytic converter coming apart and destroying the turbo. Turbos like to run warm, and STS claims that it lowers the turbo temps do to being in ambient air...People with these kits need to let it warm to optimal temps before boosting. I like the ATI kit because its intercooled boost to help avoid detonation and add more power, and some are self contained, so running oil lines are not an issue. I see boost with my d1sc at just under 2500 rpm, and pulls like a mother to redline. Belt whine is another thing i live about the kit, and the surge valve releasing pressure when TB blades close sounds sick. I also paid a lot less for the d1sc kit than the STS kit...Got everything (including 255 walbro and 42# injectors) brand new for about 4000. The STS kit is 4000 ish, W/O fuel system improvments. Either way you will be happy IMO, but i love the procharger. If i went with a turbo setup, i would go with an underhood setup with fmic and wrap the turbo in a blanket. Let us know what your gunna do! Good Luck!
Old Apr 20, 2005 | 11:42 AM
mongse_1's Avatar
Supercharger. The other choice could've been a hampster on a wheel and I would've chose it.
Old Apr 20, 2005 | 01:41 PM
5-liter-eater's Avatar
i took a 630 rwhp d1 setup off for my sts
Old Apr 20, 2005 | 02:27 PM
guardrail's Avatar
I don't see why you couldn't throw some fins on the pipe coming off the STS to the TB and actually turn the intake pipe into a intercooler.
Old Apr 20, 2005 | 03:11 PM
bunker's Avatar
Thats funny, its exactly what I said, just weld fins onto the piping, find do a lot for cooling while moving.
Old Apr 20, 2005 | 05:15 PM
GhostZ's Avatar
And you're taking your STS off for a conventional setup. You so fickle
Old Apr 20, 2005 | 06:26 PM
LukeZ28's Avatar
Everyone throws out lag, but i dont think 14psi at 3500rpms and 633rwtq at 3600rpms is that bad of lag from a base kit.
Old Apr 20, 2005 | 07:09 PM
Bayer-Z28's Avatar
Originally Posted by Kredz28
I like the ATI kit because its intercooled boost to help avoid detonation and add more power, and some are self contained, so running oil lines are not an issue. I see boost with my d1sc at just under 2500 rpm, and pulls like a mother to redline. Belt whine is another thing i live about the kit........ and the surge valve releasing pressure when TB blades close sounds sick. I also paid a lot less for the d1sc kit than the STS kit...Got everything (including 255 walbro and 42# injectors) brand new for about 4000. The STS kit is 4000 ish, W/O fuel system improvments.
I LOVE the relese valve sound....:drule:....even for turbos....HOW IN THE H3LL? Did you find an ATI kit for cheaper than an STS...lat time I checked available prices they were ungodly expensive....somewhere around $4500...mabie...Well that's at the time when I ALMOST dropped the $ for a vortech kit. Knowing what I know now I don't like all the rigging that goes into it. That's prob why I thought it was expensive, comparing to basic V-SC kit...But self-contained....I likey!! I oil pan drilling...
Well if I'm gonna spend 4gs on an FI kit (STS) I'd mind aswell get an ATI kit. What's the stock kit boost wise? 6lbs?? I understand that the LS1's have a high comp ratio and boost is a touchy thing. What else will I need? Besides fuel upgrades. Internals? I will get a cam for it FIRST so I dont have to move the SC to get to the cam, that is one of the reasons I was thinking about the STS...Underhood space not effected.. I have heard of PPL getting special cams for N20, is it he same for FI?? I might actually do a H&C before the SC....
I will be doing full roller valve trane.....FLOW THEROY!!! YESS!!! It will be about 6-8 months before I get it, though. I just want to get my mind straight before I settle.. I am NOT cutting corners w/ this car...If I'm going to dive into the motor I mind aswell do other things while I'm in there..
Thanx for the help everyone!! Give me more ideas!
Old Apr 21, 2005 | 12:19 AM
5.0THIS's Avatar
500+rwhp/633rwtq=12.1
Old Apr 21, 2005 | 12:24 AM
1982z28with18s's Avatar
12.1 isn't a good et for the power, but it did trap 126 I believe. Hell I've seen 560-575rwhp PROCHARGED vettes run 12.80's-12.90's at 117-118mph all night long at our local tracks. Doesn't mean procharger systems suck though.
Old Apr 21, 2005 | 08:32 AM
the end solution was always a huge front mount and stroker, but i got side tracked with the sts last year(fun challenge), it certainly has been a blast and made me love turbo thats for sure. Im looking forward to the new setup but im also gonna miss the ease of the sts and the look of peoples faces when there bitch slapped buy it.
Old Apr 21, 2005 | 09:11 AM
guardrail's Avatar
Originally Posted by 5.0THIS
No need to laugh, lol i was just askin. I have a s/c and front mount btw, i like it
Old Apr 21, 2005 | 10:27 AM
5.0THIS's Avatar
Just out of curiosity, what was the best time you got with your car and the STS? I just dont remember you ever posting times, but I know you were one of the highest powered STS vehicles (over 600rwhp, right?)
Old Apr 21, 2005 | 10:30 AM
F8L Z71's Avatar
I'd take the STS over the Centrifugal supercharger any day unless it is a full race setup.
I'd take a front mount over the STS any day...
