Camaro Z28 Northstar.....
Old Apr 3, 2005 | 12:34 AM
phinger23's Avatar
Possible??
Discuss...im interested. i think my motor has some serious issues...so yea im interested in maybe a northstar motor if possible
Old Apr 3, 2005 | 12:52 AM
95GRNZ's Avatar
Re: Camaro Z28 Northstar.....
With enough money, skills and time many things are possible with cars.
TS
Old Apr 3, 2005 | 01:04 AM
phinger23's Avatar
TS
well, yea true, but the average joe, with enough money to fix the car right, and not pour money into this LT1 motor i have now if its not worth it kinda person
Old Apr 3, 2005 | 04:35 AM
Z28SilverBullet's Avatar
Probably better off fixing the LT1. Engines that aren't supposed to be in certain cars usually involve more than just swapping in the motor.
Old Apr 3, 2005 | 09:43 AM
BLACKBIRD8200's Avatar
if you thought your LT1 was bad. wait to till you get your NS they're junk i have heard way to many bad things about them! and good luck changing your starter on the NS.
Old Apr 3, 2005 | 11:10 AM
SFB767's Avatar
Isn't the Northstar DOHC V8 physically larger than an LT1?
I would think so due to having two cams in each head like the Ford DOHC V8, which is larger than a SBC.
If this is true, you might have less room to work in your engine bay if you go through with the transplant.
Old Apr 3, 2005 | 11:25 AM
anasazi's Avatar
northstar is considerably larger if i recall correctly.
much much cheaper and get more power with an LS1 swap
or just fix your LT1
Old Apr 3, 2005 | 11:35 AM
myslowcamaro's Avatar
if they can stuff a 502ci in them im sure they can fit a northstar
Old Apr 3, 2005 | 12:11 PM
jakef2003's Avatar
There was a member here a few years back. Turbowash IIRC. He had a black LT1 car with a Turbo Northstar on Fikse's.
Old Apr 3, 2005 | 02:13 PM
Pandamonkey's Avatar
I remember that......I was just about to mention it myself.
I guess it takes someone who's been here a while, like us.
Old Apr 3, 2005 | 02:37 PM
Mike94ZLT1's Avatar
www.hpsalvage.com
And there it is!
Old Apr 3, 2005 | 02:47 PM
MotorCityNova572's Avatar
if im not worng ant the starter in side the motor block..??? Thats just what i was told by a co-worker
Old Apr 3, 2005 | 09:39 PM
95GRNZ's Avatar
Fix your current engine or replace it with another LTI (or LS1). Much easier and cost effective and achievable on a budget..
Old Apr 4, 2005 | 05:05 PM
you are correct. and the block is two peices put together. junk
Old Apr 5, 2005 | 05:25 PM
jakef2003's Avatar
Wow, I feel old now. 5 years
