Oil Port Hole On 350 Small Block
Old Mar 28, 2005 | 10:28 PM
masiroc566's Avatar
Hi..I was wondering what this hole is for. Its located on the passenger side right by where the starter mounts to the motor. Its right next to the oil dipstick and is about the same diameter as the oil dipstick hole. Thx all of you for your input.
Old Mar 29, 2005 | 11:54 AM
Z28SORR's Avatar
Re: Oil Port Hole On 350 Small Block
Is it threaded? There is a starter mount bracket hole in that area.
Old Mar 29, 2005 | 12:38 PM
TheGreatJ's Avatar
Just above the oilpan, between the starter and the motor mount? That's the knock sensor location. It penetrates into the water jackets at the bottom of the block...best place in the world to drain the coolant from your motor.
I don't know of any oil gallery ports on the pass. side of the block.
Old Mar 29, 2005 | 10:23 PM
masiroc566's Avatar
Thx a bunch for the info!!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
89 iroc zl1
Jan 14, 2015 02:18 AM
sskevinm
Dec 18, 2014 11:16 AM
Collector Car
Dec 17, 2014 01:12 PM
