which clutch pack kits for a 4l60e
Old Mar 28, 2005 | 06:43 PM
LT4orbust's Avatar
i'm going to be working on my engine out of the car and i'd like to replace the bands , clutch pack disc , plates and a shift kit, the trans is ok now. it goes into 3rd a little softer than it should under heavy load, anybody have a list of good clutch disc and shift kit .... i've been looking around but i'd like an opinion from somebody thats actually used this stuff.
it has a little over 40,000 miles if that makes a difference,and should have a little over 400 rwhp with n20
Old Mar 29, 2005 | 03:20 AM
Pro Built Automatics's Avatar
Re: which clutch pack kits for a 4l60e
You could add a vacuum modualator, a modified Trans-Go Performance Shift kit, an 8 Borg Warner Hi-Energy clutches for the 3-4 setup. This will help you out on longevity of the 3-4 clutches. There are additional things that can be done when you go into the unit to help strengthen the rest of it.
Old Mar 29, 2005 | 09:53 AM
timelord's Avatar
Listen to what he says,he is very wise !!!
Old Mar 29, 2005 | 06:20 PM
LT4orbust's Avatar
if it's like any of the other transmissions i've been into , for the most part it should just take removing the valve body ,frt pump and band . pull the input set,and remove the retaining ring for the pressure plates , then replace the plates and disc's... i'm just looking for the plates and disc that are known to work good, it seems all the parts stores say theirs are the best.
it looks like the red eagle disc or the z pack would work fine, are their any upgrades to do to the other packs
Old Mar 29, 2005 | 06:34 PM
timelord's Avatar
Pro Built can make you do this if you want,,,,,as I said listen to what he says!!!
4L60E
Old Mar 29, 2005 | 06:57 PM
LT4orbust's Avatar
4L60E
i have no problem listening to him, the thing is... i like fixing my car myself.
i wish my car could pull the wheels, how much for the parts you listed...for the trans guy
Old Mar 29, 2005 | 07:08 PM
timelord's Avatar
That's just it,he will sell you what you need and you build it,the black T/A is my friend and he built me my 4L60,my car isn't powerfull enough to lift yet,but nice to know the tranny will take it once it does!!!
Ringmaster72
Mar 19, 2015 03:32 PM
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
Jan 23, 2015 01:13 PM
Moshbmx1
Jan 20, 2015 03:27 PM
