Will these rims work?
Old Mar 19, 2005 | 08:48 PM
Infinity2134's Avatar
Will these rims work with my 95 camaro. They are 18x9.5. Do they need to be offset or anything like that? Also what would be a good tire match for these just for summer at a mid-level price range. Thanks.
Old Mar 19, 2005 | 08:52 PM
Zack's Avatar
Re: Will these rims work?
what kind of wheels are they or whats the offset?
Old Mar 19, 2005 | 08:56 PM
Oops.
http://pg.photos.yahoo.com/ph/infini...79.jpg&.src=ph
Old Mar 19, 2005 | 10:23 PM
Zack's Avatar
look like fat spoke c5 wheels, should work if they are replicas with the proper offset. not to sure what the offset on the OE versions are
Old Mar 20, 2005 | 12:01 AM
The 97-99 C5 18x9.5" stock wheels had a 61mm offset. That is going to put the inside edge of the wheel close to the steering knuckle, but it might work with the 18" diameter. The higher up you go on the knuckle, the more it slopes back, away from the wheel. The wheel will look like it sits a little "deep" in the wheel well.
Old Mar 20, 2005 | 04:53 AM
what if i were to drop the car?
Old Mar 20, 2005 | 04:55 AM
cash that idea i read that wrong - what would be a fix for that?
Old Mar 20, 2005 | 08:52 AM
A spacer plate and longer studs.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
