Issue with Impalae idlign low rpm timing commanding
Old Mar 17, 2005 | 11:13 AM
LTOne4Fun's Avatar
Having a problem with an Impala... it commands REAL low timing at idle and very low rpm sub 1300 (like 10-13 degrees) even when the closed throtttle spark advance table should command 30 to 40 degrees. DO you have any idea what this may be a result of? ive tried many flashed to the PCM, and believe the PCM was changed prior to all of this as well so SHOULDNT be a fubared PCM.
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
