Car running rich after new injectors
Old Mar 16, 2005 | 06:56 PM
brain's Avatar
I have stock heads with the 847 cam. Car ran great with stock injectors, made good power and the tune was dead on. I was hitting 100% duty cycle on the injectors though, so I upgraded to 30s. I also wanted to be safe on the gas. Anywho, I changed the injector size in tunercat to 31, as it defaulted to 29.9 when I put in 30. However, now it seems that the car is running really rich on motor. It breaks up a hair on the top end, but runs killer when spraying. I also put in a new walbro pump. Could the pump be stronger than the stock one causing the richness? I know a dyno tune would be optimal, but the dyno here closed. I'm just trying to think about the other possible scenarios.
Old Mar 16, 2005 | 07:38 PM
OutKast's Avatar
Re: Car running rich after new injectors
I'm going to take a guess and say that they were SVO/FMS 30#ers you put in? If yes, those injectors are rated at a different psi then your stockers. Do a search and you should be able to find the conversion.
I believe they are rated at a lower pressure hence they would spray more fuel at our hhigher pressure.
Old Mar 16, 2005 | 07:47 PM
OutKast's Avatar
Here's the thread that goes over the numbers
http://web.camaross.com/forums/showthread.php?t=131610
Old Mar 16, 2005 | 09:12 PM
brain's Avatar
Sweet...thanks Outkast. I bet that is what it is, they are indeed SVOs. I will change that and then put the wideband on it this weekend.
ro2207
Dec 4, 2014 06:18 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
