diy cable
Old Mar 13, 2005 | 10:37 AM
drewc87's Avatar
diy cable
Has anyone made their own cable then ran some type of software? I personally think that the amount of $$ people want for a cable is crazy. I'd like to make my own cable if anyone knows pin outs or any info on it let me know. Thanks
Old Mar 13, 2005 | 03:02 PM
turbo_Z's Avatar
Re: diy cable
Your best bet is just forking over the cash. If you are comfortable with soldering then you can buy the kit and make it yourself... saves you $20. From what I understand, the reason its so expensive for 94 fbods is because your only choice for the ALDL end of the cable is the high dollar molded connector where 95-97 fbods have the choice of getting the cheaper version. I suppose you could order the $65 cable with the OBD2 connector, back the pins/wires out of the connector and just plug the wires into your ALDL connector where they are supposed to go. Youd just have to be extremely careful not the pull one of the wires out out.. too risky for me, personally.
Old Mar 14, 2005 | 03:11 PM
sbs's Avatar
sbs
Re: diy cable
I built my own and have used it with tunercat for a couple of years. I'll see if I can find the schematic tonight. There are some schematics on the web - mine is just a variant on one of those.
Old Mar 16, 2005 | 12:50 AM
sbs's Avatar
sbs
Re: diy cable
Here it is. Use at your own risk.
https://lh4.googleusercontent.com/-f...o/aldl_sch.png
Also, if there's anything in this schematic which you don't understand, then I suggest you buy a premade cable.
Old Mar 16, 2005 | 10:22 AM
StickMaster's Avatar
Re: diy cable
i dont use a connector to connect to the adld thing under the car, just two wires i plug into the data and ground pins.
Old Mar 19, 2005 | 01:52 PM
Capt'n Two Rotors's Avatar
Re: diy cable
I made one similar to the one posted above but I used the max-232ecpe chip, the max233 is much easier to make, mine works fine and is hardwired into my car and I have a 9 pin serial cable that pulls out under the radio, looks pretty sweet. You can doa google search and there is about 4 different wire diagrams out there including a very simple three transistor route. I suggest doing it yourself, I was very easy and about 28 bucks and looks much cleaner than the akm adapter+adapter+adapter+adapter.
Old Mar 20, 2005 | 11:12 AM
Re: diy cable
Yea, i used the max232 chip, any rs232 chip will work fine
G-BODYT56
Jan 14, 2022 11:14 PM
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
marlar98
Sep 19, 2015 07:53 AM
AtlasXVIII
Aug 24, 2015 11:41 PM
