Theft is [upsetting]
Old Mar 8, 2005 | 05:59 PM
DrewHMS97SS's Avatar
Well, Im lucky to still have a car as I had been having an electrical issue with the car that was causing issues.
Anyhow, went out to the car to grab a tool I had left in it to find my doors open, hood popped, amps gone, stereo gone, valentine 1 gone, and steering column F@#$ED.
What I would like to know is how hard is it to replace a steering column?
Here are pics of the damage: http://community.webshots.com/album/291082066iaqRWG
Thank god the car didn't run
Old Mar 8, 2005 | 06:31 PM
anasazi's Avatar
Re: Theft is B*t*h
impossible to steal a 4th gen by "hot wiring" it like they tried to do
prolly some punk kids
Old Mar 8, 2005 | 06:33 PM
Kataklysm's Avatar
Re: Theft is B*t*h
That looks like they knew what they were doing. The column got jacked pretty good. Now you know to either not put a stereo in or to cover the amp rack...Or get the custom one that mounts onto the back under the hatch so you can't see it.
Old Mar 8, 2005 | 09:27 PM
91 Camaro RS's Avatar
Re: Theft is B*t*h
Man that really sucks.
Is it possible to steal a 3rd gen with hot wiring?
Old Mar 8, 2005 | 09:28 PM
TraceZ's Avatar
Re: Theft is B*t*h
Replacing the column is easy. Just get a new one and go from there. I've had mine out to fix the dreaded "tilt column play" problem. Tearing it all apart to fix it was not a picnic. Getting it out and in was no problem, though.
Old Mar 8, 2005 | 09:37 PM
Re: Theft is B*t*h
So how are these cars stolen without the keys? From what I see here it looks like they were trying like a ****. I though if you cut the VATS wire, and connected it to a battery it bypassed.
Old Mar 8, 2005 | 09:53 PM
TraceZ's Avatar
Re: Theft is B*t*h
No. cutting the VATS wire and connecting it to a battery will not bypass it.
Typically a tow truck is used to steal our cars. If you are not in a hurry, you can try all the different resistances until you eventually find the correct one. I've heard of a tool that plugs into the vats harness and allows the user to select different values with a ****. This method could be time consuming.
Old Mar 8, 2005 | 09:57 PM
anasazi's Avatar
Re: Theft is B*t*h
if i recall correctly, there are 26 different resister combo's
times this by the timeout period, which is something like 3 - 5 minuites per bad resister, and you've got a long long long wait.
only way your getting an f-body is via flatbed or by having the key.
Old Mar 8, 2005 | 10:14 PM
1KillerV6's Avatar
Re: Theft is B*t*h
Man, sorry to hear that. I learned something tho....that our cars are hard to steal!!!
Old Mar 8, 2005 | 11:11 PM
Re: Theft is B*t*h
but easy to get into an jack the steering column. bastards! like i said before, i should be happy to still have a car. Thx for the input.
Old Mar 9, 2005 | 10:50 PM
Getsome17's Avatar
Re: Theft is B*t*h
I dont think it is that hard at all. Instead of trying to find the right resistance to get the car to start you could just bypass the whole vats system by grounding out the vats wire on the relay in the glovebox.
Not that I have ever to steal a car but I am sure if the guy wants your car bad enough he will find a way to steal it.
Old Mar 9, 2005 | 10:57 PM
Pandamonkey's Avatar
Re: Theft is B*t*h
Jeez.......what happened to the steering wheel?
Is that fire damage?
Old Mar 9, 2005 | 11:08 PM
1KillerV6's Avatar
Re: Theft is B*t*h
No, I think thats the powder for the finger prints. Although I thought it was white?
Old Mar 10, 2005 | 07:12 AM
Re: Theft is B*t*h
It can be black too, but I'm not sure the color of the powder matters to much.
Old Mar 10, 2005 | 10:38 AM
Dave89IROC's Avatar
Re: Theft is B*t*h
all that does is allow it to crank, still won't start, the vats module sends a signal to the PCM to let it fire the injectors
