SES light flashing
Old Mar 8, 2005 | 04:18 AM
cralarcon_IROCZ's Avatar
Angry SES light flashing
I just changed my spark plugs. I put in some ngk tr55...they came gapped at .058...the same gap the stock delco's had. I was driving around the block for a test run and my ses light starts flashing. Then after a while it started to stay on and only flash when i reach about 2500 rpm. I dunno wtf is going on here. any suggestions?
Old Mar 11, 2005 | 11:17 PM
mike 96 ws6's Avatar
Re: SES light flashing
A flashing SES light indicates a catalyst damaging condition like a dead miss. If all you did was change plugs, I'd check for a cracked insulator, crossed-up plug wire {wrong firing order}, trash in the electrode picked up off the head upon installation, plug wire not snapped into proper position on the plug, did a terminal pull out of the end of a wire when you pulled them off?....
It would help to find out if a particular cylinder is is dead {cold}.
Old Mar 11, 2005 | 11:21 PM
I guess since you have an LS1 it's pretty unlikely you have the wires crossed up.
Old Mar 12, 2005 | 03:46 AM
yea well i found the problem. my dumb @$$ didn't snap the wire on my #6 cylinder. oh well....problem solved. thanks for the help guys
Old Mar 12, 2005 | 07:18 AM
Cool!
Glad it was somethimg simple.
Heathen1
Jan 2, 2016 04:27 PM
Gtpguy
Jan 26, 2015 04:50 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
