power wiring/firewall
Old Feb 28, 2005 | 05:35 PM
green93formula's Avatar
Hey everyone, I ran into a problem yesterday and until I found out what to do, I've got no stereo.
I own a 93 Formula and am wondering where the best spot to run the power wire through the fire wall would be? We couldnt find a decent spot, and the guy i was with said we couldnt drill too high because of the air bag sensors (?). Anyways... where did you guys run your power wire through on ther firewall?
Any feedback is appreciated
Old Feb 28, 2005 | 05:50 PM
LS1 RULZ's Avatar
Re: power wiring/firewall
There is an existing hole in the fire wall you can use. It's located behind the PCM under the hood on the passenger side. See this Tech Section for more info on dealing with installing stereo equipment in our cars.
Old Mar 2, 2005 | 10:37 AM
gt_biker13's Avatar
I used that little rubber thing too. Just poke a hole in it with a screw driver and run the wire through. Take the passengers side pannel off and you can see where it will come out, in a tight space behind the glove box. Look at this alarm install guide, it shows all that.(scroll half way down the page)
http://www.bfranker.badz28.com/fbody/alarm96up1.htm
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Keenan
Jan 19, 2023 12:24 PM
DarkKnight
Exhaust System
19
Oct 17, 2016 10:28 AM
NewsBot
May 16, 2015 03:40 PM
XtremeLt1
Sep 13, 2002 08:50 PM
