Running spacer at the rear.
Old Feb 19, 2005 | 01:26 AM
sssalah's Avatar
I have a set of draglites 15x10, 7.5BS with 26X11.5x15 et streets. The tires are hitting the jounce bumpers on both sides big time. If I can grind the required amount I will but it does't seem doable and think I have to use spacers. Anyone running spacers in the rear drag racing? I have the longer ARP studs BTW.
Old Feb 20, 2005 | 12:51 AM
sssalah's Avatar
Re: Running spacer at the rear.
Have to sort this thing, racing season starts within 3 days. are 5/16 or 1/4 spacers safe on the rear?
Thanks for the help
Old Feb 20, 2005 | 01:27 AM
Spinner's Avatar
No spacers are safe on the rear. Period. Remove the jounce bumpers if your having a contact problem.
Old Feb 20, 2005 | 01:11 PM
sssalah's Avatar
Thanks, very mush appriciated.
Old Feb 20, 2005 | 05:31 PM
Projectz28's Avatar
ditto. I know people who have run spacers out back but its much safer to NOT run them.
Cut the bumpers off. I cut mine off with a die grinder then smoothed the rough metal with a 4" electric grinder.
Old Feb 21, 2005 | 09:42 AM
kazman's Avatar
I just used the 4" electric grinder.
Old Feb 21, 2005 | 12:23 PM
Ken95Z28's Avatar
I agree on the no spacer on the rear. I have 28x10 on the rear and they will rub only when going around the corners hard. Straight they are ok. I cut off my rubber bounce stops.
I use to run the car with the spacers on the rear, but after what could happed it's very important not to run the spacers. You could shear the studs.
Old Feb 22, 2005 | 04:00 AM
sssalah's Avatar
Thanks alot guys, I've mocked the wheel/tire with a 5/16" spacer and it clears fine, so I'll hit the jounce bumper with a 4" grinder taking at most 5/16" and fixing them w/o spacers.
Old Feb 22, 2005 | 10:50 PM
Stephen 87 IROC's Avatar
It's a third gen pic but should be the same idea of a fourth gen. It's also not my car but mine has been modified roughly the same. Cut off the bump stop completely and fill it back in with sheet metal. I now have MT ET Drag 29.5 x 10.5 on 10" rims and there's still some room left. It's close though at the front of the inner fenders.
www.hardtail.com/pics/temp/tub2.jpg
maybe2fast
Mar 16, 2015 09:45 AM
JSK333
Sep 9, 2002 10:33 PM
94z28jbw
Sep 8, 2002 03:22 PM
sleeperZ96BT
Sep 5, 2002 05:45 PM
PROSTREET406
Jul 23, 2002 08:20 PM
