hatch struts install?
Old Feb 12, 2005 | 09:19 PM
luckyxiii's Avatar
hey all, my hatch struts are dead....i can see that the b pillar side is held on with a torx, what about the hatch side? are there any specific things to look out for during the install?
thanks
13
Old Feb 12, 2005 | 10:05 PM
shoebox's Avatar
Re: hatch struts install?
On the hatch side, you have to remove a spring clip, then you can take the weight off the strut and pull it out. One strut will not hold the hatch up, so have something that you can prop it open with (or have a second person helping).
Old Feb 13, 2005 | 01:05 PM
luckyxiii's Avatar
thanks shoebox,
ill check it out when its not rainin....i did a search and didnt see much on the topic. one more question: are aftermarket struts usually ok or is that another part that falls into the "dont buy from advance" category?
13
Old Feb 13, 2005 | 01:22 PM
shoebox's Avatar
A decent aftermarket part should be ok, IMO.
Old Feb 13, 2005 | 03:19 PM
87DJP2001's Avatar
Be carefull of that Hatch, you don't want a couple of hundred pounds dropping on you.
Nov 18, 2023 07:21 PM
dale3in98
Feb 14, 2015 12:18 PM
1996LT1Z28
Jan 14, 2015 08:09 AM
Jan 13, 2015 09:52 PM
Alien
West South Central
Jan 11, 2015 12:51 PM
