Suspensions Questions
Old Feb 10, 2005 | 03:27 PM
DontMixWithRice's Avatar
I got a job for you guys.
Identify the uses, pros/cons, of the following suspension upgrades.
Subframe Connectors
Strut Tower Braces
Rear Control Arms
Panhard Rod
High Performance Torque Arm
Progressive Rate Springs
The answers will become a sticky (or at least it should)
Old Feb 10, 2005 | 04:05 PM
ZaneO's Avatar
Re: Suspensions Questions
Why don't you use the search and answer the questions on your own
SFC - structural rigidity; sometimes hang low and interfere with headers, etc.
STB - appearance mod, IMO.
LCA - reduces weight and strength over stock stamped steel; sometimes add road noise and vibration
PHR - reduces weight and strength over stock stamped steel; adjustable function helps recenter rear end after lowering
TA - helps to increase traction under the right circumstances
Springs - generally used for lowering and added handling; many choices; needs shocks to take full advantage
F'n1996Z28SS
Aug 23, 2023 11:19 PM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Hurin
Dec 13, 2014 07:38 PM
