Chassis Lubrication?
Old Feb 9, 2005 | 01:43 PM
iCE's Avatar
iCE
Chassis Lubrication
Lubricate the suspension and steering linkage. Lubricate the transmission shift linkage. where are these located and what to lubricate with?
Old Feb 9, 2005 | 02:14 PM
shoebox's Avatar
Re: Chassis Lubrication?
Recommended lubricant is specified in the owner's manual. If you don't know where these things are, I recommend getting a manual or have someone else do it.
Old Feb 9, 2005 | 04:28 PM
mojorisin's Avatar
how often should you lube them? by steering linkage, is it referring to the shaft and the knuckle?
Old Feb 9, 2005 | 05:30 PM
pHEnomIC's Avatar
My car has the nipples for filling on the tie rod ends. I don't believe the ends from the factory had these. I usually just shoot some grease in when i do an oil change. I believe the book says 6000 miles though.
Old Feb 9, 2005 | 10:30 PM
mojorisin's Avatar
i think they all come with the nipples...mine has them too.
how often should i grease control arm bushings?
Old Feb 10, 2005 | 01:15 AM
iCE's Avatar
iCE
https://www.mygmlink.com/main/US/en/gm/home
cool site that you can custiomize for your car. it has a maint. schedule and everything. I highly recommend registering.
Old Feb 10, 2005 | 04:15 PM
Blue96z28's Avatar
Is this true? I dont think my car does....
Also I asked this question awhile back, couldn't really find anything on the search - what stock suspension parts can be lubricated, my car has alot of squeaks and rattles....
Old Feb 10, 2005 | 06:27 PM
pHEnomIC's Avatar
I think newer camaros came with all the greasable fittings sealed so you don't have to worry about greasing them. So it is very likely that you dont have the nipples. If that was the case you wouldnt have them unless you replaced a certain part.
Quickss96
Jan 29, 2016 05:56 PM
alliance12364
Sep 23, 2015 12:40 PM
97blackformula
Aug 27, 2015 06:02 PM
alphaauto
Jul 26, 2015 04:40 PM
Richardan15
May 30, 2015 08:36 AM
