brake noise normal?
Old Feb 6, 2005 | 06:44 PM
MellowZ's Avatar
brake noise normal?
Just replaced front pads and rotors with Hawk HPS and Brembos. The brakes worked fine on some 30->0 trial stops, but when I first hit the pedal there's a "thump" and during breaking there's a "thupita thupita thupita" type noise. Does this sound like usual noise from new rotors and pads mating, or is something screwed up?
Old Feb 6, 2005 | 07:48 PM
CamaroSS30thAnn's Avatar
Re: brake noise normal?
do u have ABS are u sure its just not that , if not check to c if everything is bolted up tight
Old Feb 6, 2005 | 09:16 PM
MellowZ's Avatar
Yes I have ABS, but this sound is different from the ABS sound (I know what that sounds like).
Suppose I could take the caliper off and reinstall it and make extra sure it's all tightened down properly.
Old Feb 6, 2005 | 09:30 PM
u do that and tell us how it works out
Old Feb 8, 2005 | 06:27 AM
RE AND CHERYL's Avatar
The thump is not normal, but when I installed my Powerslot rotors and Hawk pads I had a wierd sound from the brakes for a day or so. Not sure how to describe it but I'm pretty sure it was from the pads hitting the slots.
Old Feb 8, 2005 | 11:54 AM
its prolly not the same thing but i added drilled and slotted rotors on the stock settup and never had this happent to me ,
hope u find ur problrm bro
Old Feb 20, 2005 | 11:01 PM
MellowZ's Avatar
It turns out the caliper was loose . Tightened it down and it's working perfectly.
Rod Bender
Nov 7, 2023 02:30 PM
ad356
Apr 11, 2015 08:49 AM
captcorvette
Mar 7, 2015 12:37 PM
Fatdog2
Feb 12, 2015 12:24 PM
Collector Car
Jan 5, 2015 10:58 AM
