which pads?
Old Oct 9, 2002 | 10:24 PM
Deadcarny's Avatar
which pads?
i don't autocross, but i do a lot of heavy breaking from high speeds (i could swear that was a cop, dude!). i just bought some drilled (CNC'd) and slotted rotors and was wondering what brake bads i should run. right now i have the carbon NAPA pads, will they be okay? i can get the PF carbon pads for a little over $80 all the way around, but would rather save a few dollars if i can. anybody know what i can do here, i want to put these rotors on in a couple days. thanks
Old Oct 10, 2002 | 04:43 PM
BigRich's Avatar
Hawk HP or perf friction other than that they're all about the same for stock.
Old Oct 10, 2002 | 04:52 PM
Deadcarny's Avatar
would i be able to get away with a $20-$30 set of autozone brand or something pads?
Old Oct 10, 2002 | 08:39 PM
racehead's Avatar
If you do that much braking from high speeds then you DON'T want drilled rotors unless you like cracked rotors too .Drilled rotors look great, but will crack easily under heat stress. Just a FYI
Old Oct 10, 2002 | 08:46 PM
Deadcarny's Avatar
the guy warranteed them from heat cracks, so i am not too concerned about it.
Old Oct 12, 2002 | 01:03 AM
BobC's Avatar
I have a set of the Perf Friction front pads for my 95. They have less than 1 mi on them. I had to use them to get the car in/out of driveway and on/off the trailer, once, and was out of race pads till they arrived. They'd be both good and cheap. $35 gets them... EEmail me at bcurrey99@yahoo.com if you want them.
BobC
Henson071
Dec 30, 2015 09:55 PM
IndyZman
Oct 22, 2015 02:17 PM
Henson071
Sep 18, 2015 04:01 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
alphaauto
Jul 26, 2015 04:40 PM
