which rear end,need honest answers
Old Feb 2, 2005 | 09:40 PM
anthony714's Avatar
ok i need professional advice here guys,none of this i heard this or ths guy said that..i need sound advice,this is a big descision.heres my ?,im finishing up my 87 with a stoker 400,424 cid trick flow heads ,roller cam the works,dyno should go easily past 500.so now its rear end time.i know the stock one i have is just.i was looking to get a 9 inch setup,but have been discouraged by price,horsepower loss and used availabilty.id hate to loose 3 percent just from a rear.a 12 bolt is posing the same dilema.i know the some rears were of the "9 bolt" bw design and are sought after for extra strength.my real ? is can a 9 bolt be built up enough to last,and if it can,will it cost an arm and a leg to do it,or if im going that route should i just go witht the 9 incher?..its going to be stret car,minor strip and no slicks ever
Old Feb 2, 2005 | 09:58 PM
Capn Pete's Avatar
Re: which rear end,need honest answers
I'm no professional, BUT, I'd say that if you DON'T run slicks EVER, you'd probably be "ok" running the stock 10-bolt. However, for obvious reasons, you probably don't want to risk that, so then a 12-bolt or a 9" is a wise move. I know there are guys running into the 11's and even 10's on the 10-bolt, but I doubt they'd last long. There are also the odd case of a 12-bolt breaking in a ~12 second car.
Making upwards of ~500 HP like you're planning on, I wouldn't be overly concerned about losing ~3% here or there, considering the fact that you don't plan on running slicks, so you'll over-power ANY set of street tires you put on the car anyways. SO, either a 9" or 12-bolt is a good option, just go for the one that will suit your price range better, because I think that either one will be better than the 10-bolt (in case you ran with drag radials or something like that?).
That's my $.02.
Old Feb 2, 2005 | 10:08 PM
anthony714's Avatar
thanks pete.but i will add 3 percent loss is still aloss,,,
Old Feb 3, 2005 | 02:02 PM
anthony714's Avatar
hey
Old Feb 3, 2005 | 10:33 PM
fireman's Avatar
How about an 8.8?
Old Feb 4, 2005 | 12:05 AM
VILeninDM's Avatar
well, here's my story. I bought a used rear end (disk instead of drum) and rebuilt it. New gears, bearings, moser axles, support cover, solid crush sleeve, will weld axle tubes. All the parts ran a little over a grand and I didn't even get a new posi unit, which would not have been a bad idea. If you add the cost of the posi and labor (I did everything myself, but I know some people would not do that), you are looking at something in the range of 1600-1700 bucks and in the end you still have a rusty, old 10-bolt with same design flaws.
For $2100-2200 you can get a nice, shiny 12-bolt that will be bullet proof and it would be build by best professionals out there, not the local tranny shop (and this job I would definitely not trust to your every day mechanic).
Plus 10-bolt also has some kind of a loss. You are not looking at the 3%, you should only consider the difference between 10-bolt (1-2%??) and the good rear ends.
something to look at: http://www.ws6transam.org/10bolt.html
Old Feb 4, 2005 | 02:29 PM
anthony714's Avatar
thanks,that kinda answers my ?.gues ill be buying the 9 inch
Old Feb 4, 2005 | 03:33 PM
chpmnsws6's Avatar
if you want to be sure you'll never break it-
9 inch
33 spline axles (i have 31's and wanna move to 33's)
spool- get nothing less... you'll end up getting a spool if you do anyway
iron nodular 3rd member
aluminum yoke
ARP wheel studs are a MUST
Old Feb 4, 2005 | 04:03 PM
You probably don't need the extra weight... and yes, the 9-inch has been proven to lose 3% more power than the 12-bolt (5% for a Dana 60, 7% for a GM 12-bolt, 10% for a Ford 9-inch). I would suspect the power loss through the 12-bolt would be very similar to the 10-bolt... same pinion centerline geometry, and that is a major contributor to mechanical effciency. My Strange 12-bolt seemed to be within 10-15# of my stock 10-bolt. The 9-inch will add at least 30#.
Then there is a potential issue with the torque arm and driveshaft. The larger body of the 9-inch, and the cobbled up TA mount that they bolt on to it often causes problems with the TA mount/bolts hitting the DS tunnel in the 4th Gens... I suspect the 3rd Gen may be similar. The TA mount also pushes the TA off the to left, requiring a 9-inch specific TA mount. And, the pinion shaft of the 9-inch is 3/4" lower than the 12-bolt, meaning your DS has to make a sharper angle = additional wear and power loss, plus the need for a really good adjustable TA to get the correct pinion angle.
Finally... how strong do you need it? I have an 800HP nitrous setup, and the car used to be an M6. The 12-bolt had no trouble with 5,000rpm drops. A buddy of mine took his Strange 12-bolt to a shade under 1,000HP before he decided to move up to a "premium" (not your basic) 9-inch, that eventually was fine at the 1,350HP level (8.6@160+MPG in a 3,550# convertible). If you are only talking 500rwHP with your setup, the 9-inch would seem to be overkill.
Old Feb 5, 2005 | 12:11 AM
quickchicken's Avatar
you were asking about the borg 9 bolt, its actualy quite a strong rear. miles, the fella i get my parts from is running a 427 in front of his with no probs. they are rumord to be as strong as or stronger than the dana 44. reason they quit making them? cost, they were quite spendy as a new carrier last i price one a few years ago was $1100 and GM is one of the only2 places to get borg parts. miles is the other as he bought the rights.
i have 2 of them and love it. after i get my other T-5 tranny case sent to
G force to be built i can hammer with no worries of grenading anything.
the borg rear is 7.75 where the 10 bolt is 7.5 or the revised version is 7.625. they were avail from 85-89 and some early run 90 models got the last of stock.
Old Feb 5, 2005 | 11:44 AM
anthony714's Avatar
imjuneer,you say dont waste cash on a 9 inch?if so what would u recommend?
chicken ,are you saying build th esnot out of a 9bolt and ill be good?
Old Feb 5, 2005 | 12:28 PM
96m6lt1's Avatar
my buddy has a turbo ta that has a 9-bolt in it the car is full body,3.27 gears the car 60's in the 1.40 range and has no problems.
Old Feb 5, 2005 | 04:02 PM
theres actually not much to build, they are pretty much ready to go from the start. only thing thats going to be modded is a girdle which miles has been working on and on some of the third gen forums "i think" its T/A creations thats working on one pending general intrest.
i will say this, if you can get lucky , score a rear out of a 89 or early 90 model as those years got the PBR brakes. the 10 bolt plate WILL NOT fit as i have physiclly measured the plates on 2 ocasions. now drilling is not out of the ques though. so hopefully your iron calipers work or you know how to scervice them. the calipers are the same from 89-97 but the only diff is the mounting plates where it mounts to the tubes.
Old Feb 6, 2005 | 07:22 PM
VILeninDM's Avatar
anthony, 12-bolt is about $300-400 less than a 9 in. And like guys here said, they weigh less and have less power loss than 9 in. 12 bolt got my vote.
as far as I remember GM 12-bolt is about as strong as ford 9 in (although when people talk "bulletproof" 9 in is usually the one everyone thinks about, that's my experience).
Old Feb 6, 2005 | 09:26 PM
be sure when describing a rear be sure your describing it corectly as 9 BOLT, 9 IN or 12 bolt.
not flaming anyone directly for the record just reminding of clearity.
