Clutches
Old Feb 2, 2005 | 09:25 PM
stmz28's Avatar
Clutches
What would be a good Clutch to put in a 450 houre power ls1 car on the street. the car will be raced with sticks. I was reeding about Centerforce and spec ones what do you think is good.
Old Feb 2, 2005 | 09:31 PM
Valkyn71's Avatar
Re: Clutches
Spec stage 4
Old Feb 3, 2005 | 11:43 AM
David @ Thunder's Avatar
Re: Clutches
I would recommend the SPEC III clutch or the RAM 98931HD. Either will give you great driveability for the street but hold very well at the track when using slicks. The Centerforce is pretty comparable to a SPEC stage II, which really won't be enough. A key component in LS1 clutches is upgrading the hyrdraulics. We recommend the Mcleod master cylinder and newer 01-02 GM slave. Without upgrading these parts, you can pretty much bank on having release problems at WOT.
Old Feb 3, 2005 | 01:43 PM
ftransam1's Avatar
Re: Clutches
definetly get the ram clutch totally worth it stage III
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
