New England Area For members in Connecticut, Maine, Massachusetts, New Hampshire, Rhode Island, and Vermont.
4 Bolt 383LT1 Forged shortblock for sale...
Old Feb 2, 2005 | 01:45 PM
RealQuick's Avatar
I am looking to sell this as a package. The components were assembled and run for 5k miles before I got them by Aggiez28. All parts checked out fine by his machine shop. The short block is disassembled:
4 bolt block completely machined (Aligned honed, notched, 4 bolt splayed conversion) etc. The cylinder bores have a little surface rust, it just needs a a quick ball hone to clean it up. i assume you would want that anyway so the cross hatching could be put in for the new piston rings.
Cola 3.75" forged Crank (1pc rear main seal). this crank is rated as one of the best cranks out there.
Eagle H Beam 5.7" forged rods with ARP bolts
SRP -31cc Forged Pistons
Oliver Billet 4 bolt splayed main caps
ARP rod bolts and studs
The assembly is set up for a zero balanced flywheel. I will also throw in my Bret Bauer custom blower cam for an extra $250 (this cam is new, billet, and will make more power than most off the shelf blower cams). Specs are similar to a cc306, but more blower friendly. According to Bret Bauer this cam with ported stock castings, 383, and S trim @ 14.5psi should make ~680hp/700tq at the flywheel.
I am asking for:
$2200 for the engine components OBO
$2450 for engine components with the cam
All you need is new bearings and rings and your all set. Just the machine work alone would cost 1000-1200 and the rotating assy is an easy $2k for a total over $3k. This is a great deal for someone who wants to build their own power adder motor.
Please email me for questions/concerns: jrbellas95z28@yahoo.com
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
Mar 15, 2015 07:01 PM
Queens94z28
Nov 20, 2014 06:03 PM
