i ran my car on the g-tech
Old Jan 31, 2005 | 01:24 AM
blue69camaro383's Avatar
was bored and my friend mentioned he had one...so we thought...lets see what the camaro could do...
these times are not what you would call "fast" but for what this car has done to it it has impressed me some..
car was ran with full interior and in street trim...it weighs about 3400-3900lbs with both of us in it
only mods i know of done to the car before i bought it were a cam that is slightly bigger than stock,holley carb, edelbrock performer intake,headers and a shift kit when the trans was rebuilt
things holding the car back were the crap 215/65/r15 cooper tires which tend to wanna spin real easily, stock exhaust....other problem was the weight...the car was ran on a 1/2 tank of gas also.....the biggest facter also was the stock converter only being a good 1600-1800 stall...not the best
best 0-60 was 6.1 seconds and that had some wheelspin
14.77@99.5mph - manually shifted
14.82@98.5mph - left in overdrive
14.84@100.2mph - manually shifted
14.64@99.7mph - manually shifted
these times were done in 30* weather and the car still has the stock suspension and 21 yr old rubber bushings in it ....things the car will get soon are bfg drag radials on my draglite rims that will knock off atleast 80 lbs off the car, the spare tire,fiberglass cowl hood,lower control arms,subframe connectors and rear seat will be removed...fresh tune and better wires than the crappy ones on it...plus my digital 6 ignition system
the mph is almost there....my figure is the car has about 200-230hp at the rear wheels
Old Jan 31, 2005 | 07:04 AM
95redvert's Avatar
Re: i ran my car on the g-tech
G-Tech are usually plus or minus 3 to 4 tenths. There's nothing can beat a real timeslip from a 1/4 mile track!
Old Jan 31, 2005 | 11:48 AM
track is closed until april and last time i ran a different car on the g-tech the e.t was right and it was a mph off
Old Jan 31, 2005 | 08:41 PM
Yossarian14's Avatar
Hey did you post this same thing on pbnation?
Old Feb 1, 2005 | 12:31 AM
yea..lol
Old Feb 1, 2005 | 03:03 PM
Ya well I dont know how accurate those things are but your figures sound about right. As for trying to make the 305 a 12 second engine I do not think it would be worth they money because it doesnt have as much potency as something like a 383, Ls1, or anything around those lines. If it was me I would just be satified with 14 seconds and save up my money for a stronger more potent engine to swap in. A swap would be very easy and simple after seeing your engine bay, its very clean and from what I can tell you have absolutely no emission controls. Plus if you keep an old school engine over haalf that stuff will swap over to lets say a 350 or maybe 383.
Old Feb 1, 2005 | 04:12 PM
if i install nitrous and hit it with a 150hp shot...that car will hit a 12.9 or better....plus i can use it on the future ls1 install
Old Feb 1, 2005 | 06:00 PM
slimdawson's Avatar
Nitrous is a good idea. I did the same thing with my 305. Then I put the same kit on my LT1 after it went in.
Old Feb 1, 2005 | 08:36 PM
Oh my bad, I didnt know they will swap over so go right ahead. I do think a 150 shot is way to much though for a 305, maybe not for a LS1 though. How do they swap over so easily, me confused.
Old Feb 1, 2005 | 10:46 PM
its a little bit of work...but so is swapping in a normal 350..
150 is not too much, just as long as everything is set up correctly
Old Feb 2, 2005 | 12:10 AM
ryan1488's Avatar
my g-tech times are consistantly .1 slower than what i actually run at the track. the mph however, is always way off. those are my experiences at least.
Old Feb 2, 2005 | 02:25 AM
my mph is usually 1-2 off
Old Feb 2, 2005 | 12:18 PM
JSkeet's Avatar
so this is an '84 LG4 car???
Old Feb 2, 2005 | 12:30 PM
L69 car
Noenav
Mar 1, 2019 07:38 AM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Queens94z28
Dec 20, 2014 09:11 PM
USAirman93
Nov 24, 2014 03:37 PM
