1/4 Times on my 305l69 H.O motor in Bradenton florida?
Old Jan 27, 2005 | 06:37 PM
dochtermiatasbrother's Avatar
i need people's best guess, cause im going to run her real soon,like next thur soon.....
mods R /// Rebuilt Motor/Trans/
Del.Power steering/ del..A/c
Absolutely Nothing in Engine Bay but what is needed to run Car...
No Converter
New plugs/wires/cap/rotor
Trans Cooler
Dual Snorkel AIr cleaner/wich i wana sell
Ok please gimme your best guess's
Im thinkin 14.9-15.5
Old Jan 27, 2005 | 06:39 PM
Re: 1/4 Times on my 305l69 H.O motor in Bradenton florida?
O and ive heard Lowering the tire PSI at the track will help out...?? is this 2rue?
Old Jan 27, 2005 | 07:10 PM
mako350Z28's Avatar
I'm thinking closer to 16 sec.
Lower tire pressures will work with drag or street slicks, but not with normal street tires because the sidewalls are too stiff.
EDIT: Also, the rubber they use for slicks is different than that of street tires.
Old Jan 27, 2005 | 07:20 PM
ouch/ anything better than a 15.9 ill be happy with
Old Jan 28, 2005 | 12:02 AM
kandied91z's Avatar
15.899
Old Jan 28, 2005 | 01:57 AM
JSkeet's Avatar
im gonna say 15.3-15.7 only because i ran my factory '84 LG4 (150 hp 240 tq) car w/ nothing but flowmaster catback and ran 16.1@83.6mph. this run was done nov. 2003 in perfect track/weather conditions. i even did a burnout w/ the 2.73 open diff... lol... anyway, i had owned the car almost 2 years myself and never replaced ANYTHING but oil.... could've been running on 7 cyl. who knows?!!... go for it man!!
if you can plumb some raim air for that dual snorkel i'd do it... check out a local HVAC center for some tubing... or to get ideas www.ramairbox.com
Old Jan 28, 2005 | 08:32 AM
89305rs's Avatar
Well the L69 pushed the monte carloSS down the strip at a 15.7 so im guessing a 15.5-15.7
Old Jan 28, 2005 | 10:58 AM
Red25thRS's Avatar
you should be able to get mid to low 15's.....i got a 92 rs 305 tbi auto....all i got done is full exhaust...open element air cleaner...junk jet stage 2 chip....throttle body spacer...and 3.73 gears and i hit 14.8....and that was with my timing retarded 12 degrees cuz my friend messed it up....so thats not to bad for a lo3 305
Old Jan 28, 2005 | 06:23 PM
Id like 2 break 14's then i would sh$t my pants.......
LeftoverChinese
Jan 14, 2024 03:03 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
