cleaning corrosion on opti?
Old Jan 25, 2005 | 07:47 PM
worak's Avatar
my 95z is having starting issues, i know what the problem is. the distributor jumper wire that connects to the opti, keeps getting green corrosion on it. the build up is so bad it prevents the car from starting. when i clean the wire off, plug it back into the opti the car fires right up. my question is there anything that i can safely use on the opti and the plug to clean it. the wire brush technique works fine to clean the wire, but what about the optispark? is there any kind of grease or spray that i can use? any input will be appreciated.
Old Jan 25, 2005 | 08:13 PM
1 Nasty Bird's Avatar
Re: cleaning corrosion on opti?
how about a goodsize glob of dielectric grease? 2 bux at the local parts store.
Old Jan 25, 2005 | 08:44 PM
shouldaboughtthez's Avatar
ditto
Old Jan 25, 2005 | 10:46 PM
worak's Avatar
what about cleaning the inside of the opti? thanks guys
Sergio
Jan 27, 2016 04:27 PM
lildemars09
May 28, 2015 07:54 PM
