Stripped bolt
Old Jan 22, 2005 | 07:48 PM
princessleia831's Avatar
Stripped bolt
Whats the best way to remove a nut from a stripped bolt? The bolt has a slot for a screw driver on top and it has a nut threaded onto it. I am trying to install a new power window motor (not on my camaro thank god ) and it seems someone has done so once before and in the process they stripped the bolts that attach the motor to the regulator. Thanks
Old Jan 22, 2005 | 08:09 PM
KrazyKamaro's Avatar
Re: Stripped bolt
Worst case is that you have to cut or grind the bolt off and then replace with a new bolt. I don’t know maybe try vise grips on it?
Old Jan 23, 2005 | 02:01 AM
D James's Avatar
Re: Stripped bolt
vise grips work wonders, you might have to tighten the vise gripps down with another wrench. I'm having a hard time picturing what this looks like, if you can get to the nut then you can use a nut cracker-not the kind you eat, its a tool you tighten and it breaks the nut in half
Old Jan 23, 2005 | 08:15 PM
Re: Stripped bolt
Thanks...I actually ended up sawing it off to the nut and then drilling it out. What an pain in the *** that job was! Took me nearly 5 hours!
Victor Lamb
Aug 26, 2017 02:52 PM
maybe2fast
Mar 16, 2015 09:45 AM
95chwagon
Feb 28, 2015 12:02 PM
