Simple ? for you experts
Old Jan 22, 2005 | 06:10 PM
1stls1's Avatar
On a 99Z, do I NEED to get the egr fittings and such for my headers? Plus, have any of you use, or can we use, an x pipe instead of a y pipe.
Old Jan 22, 2005 | 06:49 PM
red96taA4's Avatar
Re: Simple ? for you experts
since you live in fl, get rid of AIR and EGR, since theres no emissons. if you dont get it tuned, the egr will immediately set a check engine light, and the AIR will set it afetr about a week (if you only choose to do one). what type of exhaust set up are you trying to run? i have true duals dumped at the axle, and have hooker lt's with lanes true duals (xpipe setup). so if your ? is will the x pipe fit, yes. and it sounds awesome as well.
Old Jan 22, 2005 | 09:53 PM
1stls1's Avatar
Thanks for the info.I was looking at mabe getting Kooks or dynomax Lt, but I have not seen an x pipe for sale anywhere. I want the x pipe to hookup to my TSP rumbler.
Old Jan 22, 2005 | 09:57 PM
red96taA4's Avatar
an x pipe is true duals, you use a ypipe for catbacks (ie rumbler, loudmouth) if you get an xpipe, just get some 16" or 18" mufflers and put them on the xpipe and youll have duals. i have 16" moroso spiral mufflers on mine. tsp sells a true dual setup which is very nice. it will be expensive if you want to go over the axle though, to have tips out the back
HAWG
Sep 25, 2015 11:41 AM
Sep 17, 2015 11:53 AM
colts0455
Sep 11, 2015 06:16 PM
Latronaxe
Jul 20, 2015 12:00 PM
