running nitrous line?
Old Jan 22, 2005 | 05:08 PM
kandied91z's Avatar
anyone run it under the carpet? curious as to what problems, beyond obvious of leaking it would cause and if it's a bad idea?
Old Jan 22, 2005 | 06:08 PM
MEAN_SBC's Avatar
Re: running nitrous line?
A lot of people run their nitrous line under the carpet. Just be sure the hole in the firewall where it is routed is grommeted. That's the most likely place for puncture. It's not a bad idea to run it under the carpet, just use common sense... It'll be fine.
Old Jan 23, 2005 | 06:03 AM
xfreshjiv12x's Avatar
Thats where I ran mine and there is a grommet under the computer which I put it through. Fits perfect.
Old Jan 23, 2005 | 09:51 AM
my94blackz's Avatar
I ran mine under the carpet behind the backseat, And then run it out the drain plug under the back driver side bucket. Under the car i followed the brake line.
Old Jan 23, 2005 | 02:25 PM
kandied91z's Avatar
min is currently outside the car but i'm moving the bottle forward and i don't want to have to replace the line...
Old Jan 27, 2005 | 12:24 PM
Gos2Slo's Avatar
I ran mine through the car too, so if you look under the car you don't see any lines. I also hid my switches in the glovebox, Jacobs NMM in the dash (above the stereo) and bottle in the spare tire well. If you look anywhere but under the hood you can't see a thing!
Oh, and that braided line would probably live longer passed through a hole in a firewall (no grommet) than the sheetmetal would. But run it through the grommet so it's sealed better against the elements.
Old Jan 27, 2005 | 10:27 PM
25THRSS's Avatar
On my third gen I removed the charcoal canister and line. I then mounted the bottle in the back storage area and ran the nitrous line in the factory location where the vent line used to be.
Feffman
Oct 9, 2015 05:42 AM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
