biggest safe shot on 3.1 V6
Old Oct 8, 2002 | 11:42 PM
phoenix916's Avatar
My friend has a 3.1 and wants to add nitrous and I told him not to go over a 50 shot. Is it safe to go over that on a V6? It will be an NX wet kit if that means anything. Thanks in advance.
Brett
Old Oct 9, 2002 | 02:44 AM
Joe Brodman's Avatar
GP Moderator
Well, most of the Honduh boys tend to say a max "safe" shot is around 50-55. Of course, with a bigger motor, you should be able to handle a bit more nitrous.
Good friend of mine has a 96 S-10, with the HO Vortech 4.3L. He was spraying a 75 shot, but has moved up to around a 100 or 125 shot (can't remember). He hasn't sprayed it long enough to really say how good/bad that is.
If it were my car (had a 3.1L RS, never bothered modding it), I'd spray probably a 75 shot.
Old Oct 9, 2002 | 06:13 AM
George Debski's Avatar
A good rule of thumb for a maximum shot on a stock bottom is 2hp per square inch of piston area.
This will generally keep you below 300psi BMEP at 3000RPM.
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
rideordie
Sep 7, 2015 08:22 AM
