Spraying a 2 Bolt LT1 Block
What kind of hp are you guys pushing on the 2 bolt main LT1 blocks? I only want to hear from the guys who are doing this or know someone doing it.
Now, like I mentioned before, I want to hear from the guys pushing the limits of the 2 bolt blocks on and off the bottle. My plan is to build a budget 2 bolt built for some nitrous. I'm just trying to figure out what kind of limits I'm faced with etc..
Here is my basic plan in case you want to know, 355ci:
-2 bolt block, square decked, 0.030" over, ARP studs and maybe a bit of block filler.
-Stock cast crank, stock journal size, polished mains/rod journals
-6" Manley H-beam rods
-Forged SRP pistons
-Balanced rotating assembly etc...
-Largish custom hydraulic roller cam (peak at <6500) I'll limit RPM on the bottle if needed.
Goals:
430-450rwhp N/A
150-175 progressive shot
So let's hear your stories guys. If you're pushing the 2 bolt limits, I would like to hear from ya.
Mike
-Forged SRP pistons
Goals:
430-450rwhp N/A
Mike
Re: Spraying a 2 Bolt LT1 Block
Your block with ARP studs is stronger than the crank you are plannning on running. BTW, the stock crank is a pretty stout piece. Use the search feature to find out more. Check out the truck in my sig. It's a late model 1pc seal 2 bolt block with studs and a short fill. Makes 504hp and 548ft# on motor plus a 225 shot of spray. I spray it off the line and generally torture it whenever possible. It's not even a performance block so I think your LT1 should be fine.
How much fill did you use in your block? Do you drive it on the street and if so, ever have any problems with overheating? I know a few guys do it on the LT1's but I have no idea how far they fill it for street use. To just below the freeze plugs maybe?
I'm not too worried about the stock crank at these levels. RPM's and detonation tend to kill cranks, not hp.
Mike
Stock LT1 spraying almost 200, times in sig.
We also have a stock 2 bolt SBC in a vette that just went 10.98 @ 124.
You hit the nail on the head - detonation and RPM are the destroyers. Run good gas and shift early. Peak power typically occurs at a lower RPM while spraying.
At least one if not both car will be sprayed with 250 next season.
Originally Posted by transxtreme
You will be fine. If your so worried why not get it drilled and splay the mains. Not much discussion here.
Mike
Mike
Mike
Originally Posted by onlyone07
Local guy made 634 rwhp on stock heads, rods, crank, 2-bolt, forged pistons, blower cam, stock head bolts, P600B, and a 100 shot.
Mike
Originally Posted by slp223
I have no block filler. I repaced the bolts with studs. makes power in sig.
How long have you been spraying that setup, and how often?Mike
I built the motor in may of 02 put the spray on it about a year later. probbaly only about ten bottles through. I have been having a problem blowing up drive train parts with it. motors has about 12k on it. it used to be a daily driver now it is more of a jack stand queen.
